t 650 hystat pump leak assistance
jordangibson1980
i have a 2015 t650 that is leaking from the seal behind the drive pulley. i have replaced the seal one time and it drastically reduced the leak but did not stop it. i noticed a very small amount of runout on the pump shaft while the machine is running. is this a common issue on bobcats? am i having some kind of case drain issue where there is some kind of overpressure in the case making the seal leak? any thoughts,ideas and assistance is greatly appreciated.
Main bearing failed causing the shaft to wobble and prevented the seal from properly sealing. Had to remove engine and pump to replace bearing
I'm surprised the bearing failed in such a late model machine, it runs in oil, I never thought it would fail on you, glad you got it all fixed up.
