Thanks OM, I'll see if I can sort this out AndyI uploaded the Wisconsin flywheel alternator troubleshooting and wiring diagrams info here http://www.mediafire.com/?bddcwqcw2kmlrqz
Hey Andy if you're interested in my lazy mans way of checking- check the battery voltage before and after starting the engine. When the engine is running, the voltage is somewhere around 14v, but its only about 12- 13 when the engine is off. I still dont understand why they give you an ampmeter. It seems like you get better info from the voltmeter IMO.Thanks OM, I'll see if I can sort this out Andy
So I followed the trouble shooting instructions and it's telling me the regulator module is a fault. I'll try that first but a search has yielded a couple different results, anyone know if this item from Pit electric would work with my older VH4D? http://www.pittauto.com/default.aspx?page=item detail&itemcode=WIS+YJ70AHey Andy if you're interested in my lazy mans way of checking- check the battery voltage before and after starting the engine. When the engine is running, the voltage is somewhere around 14v, but its only about 12- 13 when the engine is off. I still dont understand why they give you an ampmeter. It seems like you get better info from the voltmeter IMO.
Your best bet is to call Pitt Auto and see what they say. Make sure you have your engine serial number handy when you call.So I followed the trouble shooting instructions and it's telling me the regulator module is a fault. I'll try that first but a search has yielded a couple different results, anyone know if this item from Pit electric would work with my older VH4D? http://www.pittauto.com/default.aspx?page=item%20detail&itemcode=WIS+YJ70A
Thanks- figured I would have to do that, just hoping someone else has already been down this roadYour best bet is to call Pitt Auto and see what they say. Make sure you have your engine serial number handy when you call.
