I have a Case SR200 that just died while I was moving some rock this weekend. It cranks but will not start I thought it had ran out of fuel, and it in-fact did sort of. When you turned the key on you should normally hear the fuel pump kick on. It did not turn on after it died. I appear to have lost power to the fuel pump. I checked power to the pump, NO power to the fuel pump. When I jumped the fuel pump to 12 volts it worked as expected, I still have warning lights on the right side of the roll cage, and key switch works. I removed the cover on the left side behind the cup holder and checked each of the fuses there and had no power to anything there. The boom is down and I can't get it up at this point. Is there another fuse panel or a master fuse somewhere??? I will disconnect the lift cylinders and raise the boom with a loader if needed, so I can roll the cab over to get to the wire harness. Seat switch and lap bar should not make a difference with starting. It will start with the cab tilted. Does someone have a diagram of the fuse panel, for the life of me I can't locate my owners manual. I want to see what fuses are what. Suggestions????
