Case sr200 using a Bradco 509
Jim.butcher87
HI, I'm new to this Forum thing, so in advance thanks for all the help.
I have a case sr200 which is somewhat new to me and I just bought a Bradco 509, new to all skidsteer stuff. The guy I bought it from loaded it on my trailer with his Bobcat and pulled up the outriggers just fine. I unloaded it with my Case, I went to hook it up to my aux couplings and could not get the unit to move at all, any of the functions. After 4 hours of trying to find hydraulic diagrams on the web with no luck I switched the coupler ends and found that it would now work with the idle raised about halfway but and slowly, If I idle it up more it will work faster but still not enough to lift my unit up with the outriggers. NOW im thinking I should check the filter on the backhoe to see if it is clogged. Any thoughts or suggestions? The unit is very clean and doesn't appear to be previously abused. Also, seems odd to me that I would need to switch the quick connect ends but can't find anything on the web about a Bobcat flow being different from a Case.
