Spool valve
Cr250
Does anyone know the tolerances for the collars that the quad rings set flush against,?seems that spool valve shaft is sloppy in collars. Thanks ,Joe
Are you haveing any leaks?
They aren't super tight from memory, the quad rings do the work of sealing, so if it's not leaking after seal replacement, i'd feel they are fine. They aren't the sort of thing that would wear either.
