SB-200 Snowblower
dynarider68
I just purchased a sb200 (66inches wide) snowblower for my 753G. It throws snow but not as far as I would like it to. Now instead of going and buying a bigger unit is there anything that can be done (relatively cheap) to help this out? Thanks in advance. I read somewhere on the internet about a guy who placed a high pressure/high volume valve on the auger side right on the valve body. Any ideas on this and where I might find such an item?
The minimum flow rate for this snowblower is 14,5 GPM. If your mashine is not HI FLOW one or even it is, maximum flow will be 14,3 GPM on 753 G. This flow is small and you can not expect to throw snow away. Maybe it can be able to throw at 2 meters, no more. You can not get the flow of your machine with any valve, you need a bigger pump / with bigger flow rate /. The only thing you can do is drive very slowly with maximum engine speed ...
