S650 deluxe instrument panel
Asphalt Pat
Gurnied the s650 and now have no power supply to deluxe panel after putting down the cab.
I understand it's probably because it'd wet.
Just after a possible place to start with the air blower or has anyone else had this issue.
Cheers in advance for any constructive support
I know that some of the newer models do have a very bad problem with water getting into the conectors.
I would try disconnecting them, blowing them out and then giving them a good spray with a contact cleaner like "WD-40 Specialist Contact Cleaner Spray".
Also make sure that you didn't accidentally pinch or pull apart a connection when lifting and lowering the cab. Bobcat is not the best at securing and running wires.
