s300
353detroit
Hey guys, I have an 05,s300, I bought this machine as a basket case, it runs great,lifts,tilts,but wont move pump has been tested as good,we cant get it to roll, only forward on the right side but not reverse and no movement on the left,when we try to move it it stales the machine,but other times it has moved fine,thanks for your time.
I should have added it dose have good charge pressure and dose not have any codes
As the pumps have been tested and you know they are good, it has to be the drive motors or park brake.
As you say if you move the steering levers it will stall the motor, something is locked up.
I assume it's a bobcat S300? they run a wedge and disc brake setup, the coil pulls the wedge up and allows the disc to move, when off, it falls and locks the wheels.
