S250.The drive shaft seal of the hydrostatic pump.
nester
Hello. To change the seal, you must remove the hydrostatic pump? Or enough to remove the pulley from the shaft and there is access to the seal?
I've done it 873s, but it was tight. Those don't leak normally. I would pay very close attention to bearing play. I didn't think I had any play to worry about, but the seal lasted only 10 hours or so. Customer traded it in on a 650.
Today replaced the seal. As it turned out very easy. As I was expecting, the hydrostatic pump need not be removed. Just remove the drive belt and pulley.
