S130 press to operate no workie
Ajb86
I have 2006 s130 that was operating fine, shut it down now i can start the machine but the cant get the "press to operate loader" button to activate where should i start. Further info I have no codes on the hour meter as the hour meter stopped working after about 12 months old
seat bar light comining on? next step examine bics lockout coil is it cracked or show signs of heat?
Thanks for the reply mate, no seat bar light but can hear relay switching when you put it down, where abouts is the coil for the bics lockout located
Without the light coming on, i still suspect it's locking you out.
The solenoid will be on the control block.
The newer ones have small solenoids that have a pin that locks the lift/tilt spools.
I would suggest either replacing the hour meter / digital display as to better get more information from the fault codes - OR - I would take it to the DEALER so they could possibly "scan" the on board computer for those codes before deciding to replace the hour meter / digital display. Without knowing if there are any codes _ OR - what they are, you will be just wasting time, money & your sanity by guessing at what 'could-be' wrong versus knowing for certain. Be VERY careful with this issue. It kinda sounds like a catch 22??
