Hello all,
First, just a quick thanks to the forum as I have learned a lot when I have run into issues in the past with our machine. We don't use it for a lot of work and often have the dealer service guy work on it.
The lift hose blew on it yesterday and finally got a chance today to take a closer look at it. I was thinking to replace both the tilt and lift hoses as it seems would be easier to get at the lift hose in behind the tilt hose if both were removed at same time plus I think they are both original on the machine.
I want to make sure I am taking it off correctly because although I have searched I haven't found this specific hose change out in youtube videos or forums.
So, this is what the connections look like under the arm and then go further down into the engine compartment:
Can I remove this top connection first and then have room to reach down into the engine compartment from the top or do a need to undo the ones in the engine compartment from the back door (there is another larger set of hoses in the way so seems would be harder to get in that way).
I tried using a 1" wrench and a 15/16" wrench but it looks like they might be metric connections as it is a little loose.
What I was trying to do was hold #1 part in the pic up with a wrench and then pull #2 down (i.e. to the left). I didn't want to put too much pressure on it in case I was doing it wrong or in case I had to remove the other side first.
I am sure for people familiar with hydraulics this seems like a pretty basic question but would appreciate any tips. Also, since the lift hose has a hole in it I know there isn't any pressure in it but do I need to worry about pressure in the tilt hose if the power is off? I know how to release the pressure in the aux hoses but not sure how to release pressure in the rest of the system.
Expecting some snow tomorrow up here so hoping can get this resolved at some point on Friday to get the machine back working. Our dealer is booked up until mid next week otherwise would have had him come and take care of it and do some other service on the machine.
