I've tried spinning the cap and checked to see if it fit in the tilt spool chamber and it does yet the screws also do not line up.Just did mine on my 853. You may have tried this but try rotating the housing 180 degrees. It makes no difference to the action of the spool itself and there shouldn't be any reason it's out like that. I know sliding mine back in just needed a bit of finesse to get the seal to seat itself, but otherwise no issue aligning bolts. It's in the right sleeve?
Yeah. Thats a good idea.That's strange for sure. The cap shouldn't misalign as the end goes through the top of the cap with the detent sleeve. It certainly doesn't appear to be out of square in the photo. Perhaps pulling the spool apart again and dry fit just the cap to be sure.
I took apart the spool and put it back together and took the advice of the service manual and used loctite to hold that center screw at .600" instead of letting it screw in with the cap. And it lined up just fine after that.That's strange for sure. The cap shouldn't misalign as the end goes through the top of the cap with the detent sleeve. It certainly doesn't appear to be out of square in the photo. Perhaps pulling the spool apart again and dry fit just the cap to be sure.
