Relays on bobcat 763 high flow
arthurelksjr
Can relays cause the machine not to crank. We check starter, key switch, and other things and still will not crank using key. Starter will turn over the engine using jumper wire and fuel solenoid does not click when you turn key on like it used too. Please help.
Sure that can be the problem. Are your relays labeled? They were from the factory but may be hard to read. Just swap one of the relays for the starter relay and give that a try.
