problems with bobcat rotary broom
pageman21
hi. i have an 04 S250 and i'm tryin to run a rotary broom. it has the 14pin plug on it and the hydraulics lines. the broom works fine, but when i try to shift it from side to side. it starts to go for just a second, then stops. the machine beeps at me, and flashed ACD on the instrument panel. then i have nothin. but when i shut the machine down and restart it. the ACD is gone then it does the same exact thing. any help would be greatly appreciated. travis
when you have the problem and machine beeps at you push and hold light button and wait till hour meter changes to a four didget code. need code to trouble shoot.
also you need to have the hydrolics running to move the broom left or right. otherwise you will have the problem you are having.
