Sid... Having a bit of trouble with my 863 starting (same Deutz engine as your T200). Normally starts on first crank, or maybe two. In the past few days, it's begun to not fire on 4 or 5 revs. I've stopped cranking, then retried. After a few iterations, it starts on the first engine rev, as it always has before. I'm suspecting the fuel shut-off solenoid is getting tired. I've checked voltage on the white wire going into the solenoid (1-1/2" dia, 4" long, right side of engine near the rear door), and it's always been 10v or more when it cranks and starts. Haven't yet caught it when it won't start to see if there's voltage there or not. I've swapped the fuel relay with the starter relay and checked the fuel solenoid fuse and contacts. [Actually, this may have solved the problem since it hasn't failed to start since I did this] So the question for you is: how did you diagnose the solenoid problem and what were the symptoms that led you to it being defective? Is there an ohm check I can do that will reveal anything? Also, where is the manual shut-off switch for the fuel? Is that the 1-1/2" long lever just below the solenoid that doesn't connect to anything? It will rotate manually about 90 degrees. Many thanks,
Bobbie-G
