NH LS170 Flasher Module.
jimcar11
Can anyone help me finding the location of the flasher module on a 2004 NH LS170 skid steer. The manual says it is on the right inside the cab by the roofline. There is an elecrical compartment there but only contains the service/run switch and 4 fuses. Actually there should be 2 modules-one for the 4-way flashers and one for the directionals. I can't find either. Thanks for any help you can offer. Jim
Depending on which headliner you have you will either need to remove the headliner, if the headliner goes from side window to side window, or just the vertical plate next to the fuse panel which supports the narrower headliner.
Thanks alot for the info. I have the full headliner with the heat vents so I will have to decide if it is worth it to dismantle all of that just to get a new flasher module put it. If I knew where it was exactly I would cut a hole in the liner and make it easier the next time I have to change it. Thanks again for the info. Jim
