chezmichaelanthony
- Joined
- Mar 30, 2025
- Messages
- 4
I tried to make this as brief as possible. 2008 New Holland C185 began running a little sluggish, and hard starting. It would run well after starting, but would bog down under heavy load. Probably had this issue for about 15 or more starts and runs. Turned the machine off one day, a couple of hours later, crank no start, no smoke. Checked for fuel and air delivery, replaced filters on both. Based on the fuel filter condition, went ahead and replaced the mechanical fuel pump (and it didn't seem to have much pressure when trying to prime). When I cracked the 1st fuel line on the injection pump (a VE3) I discovered the pump was loose. After further investigation I found a sheared mounting bolt, a missing bolt and a small break on the pump housing where the sheared bolt was located (found the broken piece and bolt in the bottom of the engine bay). I can't fully see the interior/engine side of the pump, but it doesn't look like there is a mounting bolt, looks like only a guide pin of some type (as seen thru a digital scope). Knowing little, but willing to learn, I took a lot of pictures until my phone died as I started removing lines and electricals to get the pump out. The pump was loose, I could twist it less than an inch using moderate force, but it wouldn't come out. Assuming at this point there must be something additional attached, I raised the seat and removed a small metal plate held with two bolts that exposed the end of the pump that's mounted to a gear. I removed the bolt holding it to the gear, but it still could not get the pump out. I assume I need a gear puller to get it off the gear, but can't find mine, so currently in a holding pattern (also have to go back to work) When I twist the pump, the gear moves a little loosely as well, just wiggles a little. Questions are many. Should there be 3 mounting bolts or just 2 and a guide pin on the engine side of the pump? If there is supposed to be 3, I have no idea how any tool could get in the small hidden spot. Are there any other bolts or mountings after I get the pump off the gear? I have to get the small area of the pump welded that broke at the sheared bolt and remove the sheared bolt from the engine, but should I also get the pump tested once removed? If the pump is okay, do I need to worry about timing? The engine and pump at this point hasn't been turned. Should the gear inside the engine while looking through the opening created after removing the metal plate behind the seat move when I twist the pump move around slightly? The gear moves a little along with the pump, it doesn't seem to be damaged, but when I get the pump off the gear, the gear seems as though it will just drop and isn't connected to anything else. Any thoughts on why this may have occurred, the bolt shearing? I'm not sure if the bottom bolt is sheared or just wasn't there when we bought the machine about 3 years ago. Thanks for any thoughts and I'm sure I likely forgot more questions, just kinda spent right now.
