new to me 751 question
boz
I recently got a 751 and there is a small coolant hose coming from under the engine and is not hooked to anything and I cant figure out where it goes does any one have a picture of the engine compartment so I can compare the routing of coolant lines?
Either for a cab heater or a tank style block heater.
If it's a pug, they have hoses everywhere!
If you check your parts manual, it will show if it's meant to be hooked up or not. Hopefully it is just a heater.
Got a hold of a manual and found out it's hooked up to a coolant drain valve on back side of motor I was able to turn 1/8 and stop the leak po just did dip tube in fuel tank and may have knocked it loose thanks for the help
no disrespect. if it got the puegot. wash yore hands as quick as possible. even if youtake hit. better now than tommorow
