Okay. That’s a great tip. I’ll take a look. CheersIf it functions smoothly when stationary, I'd suspect that it's starving for fluid, either because the level is a bit low or the pump is cavitating because the flow is restricted.
All filters should be on the return side and shouldn't really cause this, but I suppose that they could cause enough back pressure in extreme cases to impede the flow.
It's a place to start; hopefully someone will be along that knows the systems on these and can offer more help.
check to see if there is in addition to a regular filter, a filter screen in another part of the hydro circuit . and since your into it if your skid steer has a case line drain it might have a filter too. prost!Okay. That’s a great tip. I’ll take a look. Cheers
