New holand LX885 TB shuts off at 130*F
CrashBurning
Have 885 New holland that runs fine tell it reaches about 130*F and then shuts down... Let it cool off and she fires right up and runs fine... Then quits after it warms again... No codes showing up and water and oils are all full... Any ideas on issue would be great... Fuel bowls are always full and no signs of air in fuel system..
A partially shorted fuel solenoid could do that. Is the fuel solenoid hot to your touch, or showing signs of damage? On the more extreme side the fuel pump itself can do that too, but usually it wouldn't show up till hotter. If the fuel pump happens to be the issue, it is most likely caused by water going through it and you would find water in the bottom of the fuel bowls. The solenoid isn't related to water, just wears out. Don't know how to test them, I've always had a spare around to try.
