SkidRoe
- Joined
- Dec 10, 2009
- Messages
- 1,885
The stock alternator in the repower is barely cutting it.
The original Kohler had about a 20 amp charging circuit, and the 20hp Launtop only has 3 amps on tap (engines with 20 amp alternators were available, but I got this engine cheap). It is barely passable to recharge the battery after starting, and running the fuel pump / fuel shut-off solenoid (so long as you are not starting and shutting down a lot), but lights are out of the question.
I priced the Honda parts to put their 20 amp alternator coils / regulator in, and it comes out to about $400, plus you have to pull the motor to do it (fly wheel has to come off).
So my plan is to belt drive a second alternator from the crank shaft. I picked up a new 55 amp Denso one-wire for about $85, and will be installing a 4” pulley on the crank to drive it. These alternators are becoming really popular with hot-rodders, as they are really compact.
The parts are coming together and I am hoping to get a start on it over the weekend. And I will be taking pictures.
More to come,
SR
More to come,
SR
