I just replaced both seals on one side of my 1200 last week, as they were leaking very bad. The manual says that after you remove the castle nut and cotter pin, you need to press the shaft out. Do this by placing a hydralic jack against the other side frame. The shaft only needs to move about 1 1/2" and it will come out. I found there was enough slack in the chain for the main drive gear that I did not have to remove the link, just slide the shaft out. There are 3 collars on this shaft that will fall out when you remove the shaft, 2 on the inside of the main sprocket gear and one on the outside (wheel side) of gear. Try to catch them when you pull out the shaft, or you will be fishing them out from the bottom of the tank. You will have to crawl under the unit to remove the rear shaft, the front shaft can be accessed from the battery compartment. Once the shaft has been removed, I found the shaft had a groove worn from the seal, which caused it to leak. Very common problem. I had the shafts rewelded and turned to get a new seal surface ($90 each shaft). The local Mustang dealer had a shop they worked with. Reassembly is easier with 2 people so that you can get the collars positioned when you insert the shaft into the main sprocket gear. The manual says to tighten the nut to draw the shaft into the bearings until you take up the side to side slack in the bearings on the shaft. If it becomes too tight, you can loosen the nut and tap on the shaft from the inside with a lead hammer to gain more slack. If you need part numbers for the seals, I can get these for you when I get home. Good luck and let me know if you have any questions. I can always fax you pages from my manual if needed.
