Mustang 2054 Starting problems
Rhinopower81
Hi guys, I'm over in the UK, I have a 2016 Mustang 2054 with a Yanmar engine. It needs a shot of "east start" ever time I need to start her, even if it's been running a while. Once started she runs as normal with no smoke or lack of power.
I've changed fuel filter, cleaned fuel lines and changed the lift pump.
Any ideas?
Thanks
so It doesn't start & shut off ? Just Cranks? Your Lift Pump Is Electric Correct? Make Sure It is Pumping
take line off at filter base you should have a good supply of fuel from hose If u have a good supply, Check voltage at the
white wire at fuel solenoid, should have 12 volts only during cranking
