Thanks for reply . No leaks everything else works fine . No leaks . Right track will not move.. It acts like it is in a bind.I apologize for the Council. I have not understood the question correctly. This most likely is a problem in planetary gear reducer /final drive/ on right track or broken shaft of a hydraulic motor.
It will be not cheap. Gear or broken shaft. Remove track and remove final drive. Disassemble it or refer it to repair.Thanks for reply . No leaks everything else works fine . No leaks . Right track will not move.. It acts like it is in a bind.
As much work as it sounds, swap motors side to side. This will tell you if the motor is the problem if the problem follows the motor. I wonder if the brake is not releasing on one side.It will be not cheap. Gear or broken shaft. Remove track and remove final drive. Disassemble it or refer it to repair.
