Melroe 742 4 cyl hydrulic problem
Jggreen5
I recently started having issues with my bucket and boom operating sluggish, I washed out the compartment underneath the cab to try to remove some of the gunk in there. When I went to run the machine the boom would only go up and very slowly, I couldn't press the Pedal all the way down or it wouldn't move. The bucket will only dump and barley I changed the hydrulic filter and topped off the fluid. Any idea what could be wron with the hydrulics?
Make sure that there is not debris under the pedal or restricting the linkage movement yet. When you have full movement of the hydraulic valve spool then you can go from there.
That's where I was heading at first I vaccines all debris and washed dirt out and cleared the pedals
