MC70B leaking hydraulic fluid into be=gear box
retiredusaf
My left side drive box is over serviced and started leaking threw the parking brake cog into the hydraulic bay of my skid steer. Is this a sign that my drive motor needs to be resealed? If so, is it the front side or back side of the motor? I have done several hours of research and can't come up with much on resealing the drive motor. Any help would be greatly appreciated.
Depending on the style of drive motor, some have seals on the high pressure side, but the low pressure/case drain is open. There should be a seal to stop fluid passing from the open side of the drive motor to inside teh gear box. Bobcat have this setup at least, if the case drain filters have a restriction, pressure can build and push past the seal.
Hopefully your issue is this simple, just a bad seal to the gear box.
Hopefully someone that has one of these can assist more.
Id noticed hydraulic fluid leaking from my parking brake too. I spoke to a local, long time volvo sales/service rep that it was the motor seal leaking into/over filling the gear/chain drive oil box nd leaking out the brake actuator (first place fluid can get out). He says the seals on the motor are proprietary and, even if you could get them replaced, would liky leak soon due to the worn motor's shaft 'walking' and compromising the seal again. Guess It's a common problem after the motors have worn.
I had just got the machine back up and running after not seeing use for almost a year due to tracking down another part and getting it back online. So, I just drained off the excess fluid at the chain case service port for the moment and hoping (praying) that running the machine might restore the seal. If not, gonna have a another project.
