GlennsM444
- Joined
- Sep 9, 2013
- Messages
- 55
I finally got my M444 up and running. Things were going well for a few hours and then she started cutting out. I thought it was a carburetor issue again but when I looked under the hood the front spark plug (right if looking at flywheel) was spinning in its seat and leaking air. I tried taking the plug out and to no avail - it just spins loosely in its seat. I removed the head and it appears the plug is bolted tightly into a "sleeve" around the thread of the plug that is loose in the head. I tried yanking the whole thing out with a vice grip and to no avail. 1. Does anyone know, is this sleeve usually found in Onan heads or is this some type of "re-thread" job that someone did over the years? 2. If it is in fact a manufacturer sleeve, is it steel or aluminum? if it is aluminum I might ask a friend to tig weld a bead around the base to seal it up. gc
