Paul of Chester
- Joined
- May 18, 2012
- Messages
- 8
Hello, Several months ago I bought my first bobcat. An M700 jalopy. Like my backhoe and farm tractor, it is well used & abused when I got it. I was correcting the routing of some hydraulic lines when one thing led to another and I had the floor plate up and removing the rods that push & pull with the peddles. I discovered that "well" under the floor plate had 1&1/2 five gallon buckets of the nastiest hard-packed oiled up dirt in it. After cleaning out everything I started to wire-brush the area to prep for paint. Man was it rusty. huge pits in the metal. When I brushed one of the hubcaps oil started to spew out of a pinhole. Nothing is ever easy. You know when they say "the only thing holding that together is the rust" well... I need to replace both front hubs. I can't get enough information from the maintenance manual to help. I'm not sure if they are one piece or two? The part that bolts to the wall is clearly 1/2 inch thick. The rounded center is thin enough to get a hole poked in it. I welded together a wrench to see if it could unscrew (relieving where the two parts came together, there is no visible crack). All I did was bend the metal a little. I'm afraid to undo the four bolts because I'm not sure if they hold on the wheel or if the hub hides the real wheel bolts? Can anyone give me some advice on tearing this down? I would like to include photos like some of the other threads but I haven't figured out how to do that. Thanks for your help Paul
