claytonncguy01
- Joined
- Nov 19, 2011
- Messages
- 3
I'm not sure if I ask the question correctly. does anyone know how to replace the hydraulic fluid in the LX865? I want to drain the fluid and put new fluid in... thank you in advance...
thanks mike you been a great help..... this site is wonderful.....Remove the small bottom access plate under the engine where you drain the engine oil. Look to the right of the oil pan and you will see some large hydraulic tubes. Disconnect one of the fittings and the oil will drain. It takes a 1 1/4" wrench. The lines could be attached to small juction block or connected to each other depending on the age of the unit. It doesn't matter which you take loose.
My LS185.b has a 2 foot long clear hose that is plugged that runs out the back of the machine to drain the reservoir.thanks mike you been a great help..... this site is wonderful.....
