I got a new bearing kit for the final drive.My first question is on reassembling the drive do you press the inside bearing up tight to the bearing race cup,does the bearing stop or can you over press the asembly?Thanks for the help
When you talk about the inside I guess your talking about the Last bearing going on. You would want the bearing to seat and not have any back and forth. dont put a lot of presure when seating the bearing.After your bearing i seated grab the axle and push and pull lightly , you shouldnt have back and forth movement.
You have to put the right amount of shims between the snap ring and the bearing. When its all assembled it should turn freely, not be tight and not allow the axle to move back and forth in the housing.
When you set the bearing on a truck you take it up snug. Turn the hub and feel when it gets resistance while tuning,and you back off on the nut just enough for it to smooth out. [No Binding] No Slop]
Since you dont have the axle nut to ajust the end play you have to get those shims right.Skid steer tire get a lot of side force. the parts guy said people swing around and hit the side of the wheel and that cracks those snap rings I caught mine when I had 1\4 inch back and forth movement.
Put sealer on your axle housing when you put it back on. Hope this helps. Mike
