Oil pressureI'd suspect oil pressure. It would be the pumputer trying to save the engine in the event there is low oil pressure for 30 seconds. Hopefully its just the cold or a bad sender.
where is the charge oil pressure sending unit located on this machine?? i looked and can not find it. thanksOil pressure
Water temp
Charge oil pressure
or any malfunction of the protection system that tells the computer one of these 3 are out of range.
On the LS 160 its the two wire sender near the hydraulic filter assembly. It is designed to complete the circuit when pressure falls below 50 psi.where is the charge oil pressure sending unit located on this machine?? i looked and can not find it. thanks
