Dieselrider
- Joined
- Jul 30, 2011
- Messages
- 12
I have a LX665 that has been giving me problems starting. At first I was able to unlatch and latch the seat belt a couple times and it would fire and run properly. So I believed my seat belt switch was bad. However, the seat belt switch checked with an ohm meter reads closed each time the seat belt is plugged in. My next suspects are one of the two seat switches under the seat. The contacts were corroded so I cleaned them and tried again. Machine will not start and the park break lamp continues to flash after the seat belt is plugged in. Also the seat switches appear to make contact each time when depressed. (Again checked continuity with ohm meter on the bench). Could they just not be getting depressed enough while in the machine? Can I jumper across the contacts to see if one of these switches is bad or are there other things in that circuit to look at first? Thank you for your input.
