Great Forum! First time posting. Thanks. My LS185.B quit on me. Figured it was fuel, so I traced the lines. I found a hole rubbed in the line between the tank and the fuel filter. I replaced the fuel line and can manually pump fuel now into the filter. I have loosened the banjo bolt on the top of the injector pump like the manual says to do to bleed the lines. I can't get fuel to come out. As I continue to pump the hand pump, it becomes "loose", like it is not pumping anything. If I loosen the bottom of the fuel filter, air sprays out and them the fuel, then the hand pump "stiffens" again. I am assuming that I am not bleeding the lines correctly. How does one correctly bleed the lines. I am assuming this is the problem for it not starting. There is no smoke at all coming out the exhause when I crank. Thanks
