L785 intake heater help
jwolfe3
I have an early 90's model L785 skid steer. I haven't had it long and we are into cold weather. I am trying to get the intake heater to work. I have confirmed that I have battery to the heater and can see it glow. There is a fuel line that goes from the fuel pump to that heater, as well. The best that I can tell, is that there is no fuel getting to the heater plug. I have taken the line off and the pump and there is a little bit coming out, but none to the top of the line. I did make sure the line was not plugged. Any suggestions as to what the problem may be or what to try next? Thanks, in advance!
I have same machine in NY never used my heater on Perkins 6200 hours no issues .
I give tiny shot of ether lites off instantly
Also I found the Starter is the same as a 2000 GMC 6.5 diesel ND Japan made all match except the drive end . Cost $70 versus $700 at dealership.
I put a GM Delco single wire alternator on it also.
Best machine no problems since 1994.
John Deere put their name on these New Holland skid steer then .
Same machines.
