L785 Fuse Box Location
mfyock
I see in my electrical schmatics fuses mentioned, but I still havent been able to find the fuse box on my loader. Anyone care to tell me where its at? Thanks Mike
Mike
I have a lx 865 but maybee they are similar. In the cab look up on the right side above the wire mesh where the cab frame makes a box. there is a small plate thet has two thumb screws. In mine its by the service switch.The cover plate is about 3x4 inches.
There is another fuse box in the engine compartment, Remove the left engine compartment panel. The fuse box has a plastic cover to the left of the back of the seat. One box has relays and the other has fuses.
Yours could be different. Mike
Mike
My '05 LS185 is like Mike describes, except the box in the rear has diodes, two types of relays and fuses, and a ceramic ballast a la the old Chrysler products.
No luck. Searched were you said and still no fuse box. Any other ideas?
i have a 565 which has the panel mike describes but also if i open my rear door then lid , there is a fuse bank on the left mounted to what would be the "firewall"
