You can bypass the cooler as you suggested, but my thinking is, if the hyd pump is putting out 14 gpm the oil has to be going somewhere since the hydrostats do not take that much flow since the hydrostats are a closed loop and the only oil going into them from the circuit is what is lost through the case drain. If the flow was being that restricted at the cooler I would also think the pressure would increase to a point where the cooler would explode. Having said that, the only way to know for sure is to either tee a pressure gauge into the circuit before the cooler or do as you suggest and bypass the cooler. It would be better yet if a gauge could be installed before the filter, but I don't believe there are any test ports.The boom is not noticeably slower when the charge pressure is lower. I know that 120 psi is lower than the 160 psi that this brand new charge check valve should keep it at, but from what I've read in other people's problems on this forum it sounds like the hydrostats should still work at that charge pressure. My machine won't work right even at start up when the charge pressure is 145-150 psi. I've read about people working their machine as normal until the charge light comes on and then even continuing for a while with the light on (and that means less than 50 psi). What does the control valve do besides distribute fluid to different circuits? Is there something in there that could restrict the flow to the hydrostatic circuit and cause this sort of problem? How about the oil cooler? Maybe it is partially plugged? Pressure in the oil cooler should only be charge pressure so couldn't I temporarily bypass it with a 300 psi hose? That should rule out a restriction in the oil cooler right? Also the charge pressure switch is immediately after the filter on this machine. It does seem to be leaking a little bit too. How would I go about inspecting the filter housing? Just remove that filter and look at it?
