The service manual calls for fluid meeting the J20A spec. The dealer says NH 134B spec. The oil I bought was the cheapest tractor transmission/hydraulic oil they had but it said on the bucket that it meets both of those specs. They do have some that is more expensive that meets the newer specs (J20C and NH 134 B,C,D). I may try that If I have to. I removed the suction hose (it is new and in good shape), cleaned the nipples greased them and reattached it with 2 clamps on each end. I couldn't get the hose fitting on the gear pump off because it requires a wrench that is bigger than anything I have (it's bigger than 1 5/16 since that's the larges wrench I have). So I could still be getting air through there I suppose. The machine sat since Wednesday so I figure most air would be out of the oil. I started it up and the charge pressure read 150psi. I backed it out of the garage (ran jerky and weak) and worked the boom and bucket cylinders a little. After maybe 10 minutes at near full throttle the charge pressure was down to 130psi. Then after another 5-10 minutes it was down to 125. My son would move the machine and I'd look at the pressure and it would drop to a little under 100psi. It runs no better than before -- exactly the same. The charge light didn't come on but the manual says the charge pressure should be between 150 and 190psi. Does anyone have some advice on changing the charge check valve. I bought a new one but I'm not sure how to get that thing out. It's hard plumbed into the oil return and there isn't any give in either direction. I think I could get it out if I removed the other line (the charged line) but it's behind the line with the valve in it. I don't see any way to get a wrench on it. Also I made a video of the machine attempting to drive. I tried to make it a "landscape" oriented video but it was done with my phone and it didn't flip correctly. I don't know if the video will help but you can see it here http://youtu.be/cThx5pm27Fc
