just bought my first M600
Here is a link to posting pictures:
http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=2445
And ignore the nay sayers. Glad to hear your project is progressing well.
HTH - SR
appreciate it, and I personally don't care what others think. im a 27yo electrical engineer with a decade or more of experience in general construction and the machinist trade. combine that with being an insomniac and a girlfriend who works nights, and you end up with a mind that dosent shut off and a whole lot of free time. its also very helpful when your dad, who is a retired machinist gets bored and puts in a shop at the house haha. I enjoy the projects where people say it cant be done or its not worth it. the way I see it. its not costing me much, im learning a lot, and ill have a nice toy to call my own.
My apology…..I answered your serial number question on the other thread before reading this one and seeing that you had already contacted bobcat for the info. Keep at it.
Hi Guys, thanks for the comments, the machine is coming along nicely. so far here is where I stand: all the hydraulics have been removed and I am waiting on the dealer to get back to me on what seals I need for the control valves and the cylinders. all of my flex lines have been sent out to be made. both head gaskets have been replaced, ( the cylinder walls are in great shape). the whole machine has been sanded down and I am in the process of repainting it. the next thing I need to debate is if I pull the motor to set the timing or if I go old school and just do it by ear. to the individual saying its a waste of money. I plan on using this machine for general yard work and snow removal, so the low lift capacity and slow sleep will not be an issue. and as far as the money wasted. the initial cost of the machine was 500$, and so far between a new batter and random parts like plugs, wires, and hydraulic oil. im only into it for another 220$. baring a complete failure of the motor... I should have a fully functioning machine for under a grand. now to those who have some experience with these motors.... the governor... is it supposed to be spring loaded in one direction when off? or is it supposed to flap in the wind? when the engine is off the throttle plate is not held in any particular position. I will provide picture as soon as I can figure that part out.. thanks ahead of time
There is no need to pull the motor to time it. there are timing marks on the flywheel/fan. On the back right side of the machine there is a vent that goes to the cooling fan / flywheel. There is a round screen on it, pull the screen off, I think 4 screws. There are two timing marks one for VH4D and one for the VF4D. put a regular old timing light on it, adjust the timing until the marks line up. Pretty simple to do really. Just make sure which engine you have, as the timing is different between the two. The 600 should have came with a VF4D but many were converted to the higher hp VH4D.
I do have the vh4d, or so I would believe the sheet metal on the motor. Looking through the side vent, once I take the screen off. What am I living the timing mark on the fan up to? I'm used to a degree I dictator or something... I'll head out to the shop in a few to check that one out
ok here we go, I guess the HTLM editor is not friendly with chrome, time to upload some pictures...
she looks in sorry shape when I brought her home, again keep in mind, 500$
inside the fuel tank is a little rough..
after a bit of cleaning
had to machine a carb spacer at the throttle arm was hitting the intake above
cr@p filled lower tank..
new water proof wiring
braided stainless covering on most of the new wire
some what cleaner
a lot of carbon build up
damage to where the lift arms connect from decades ago
and as she sits
I apologize now for the massive picture dump.
Take the screen off the flywheel shroud. Find one cooling fin that is marked/stamped with an 'X' (It is in line with the 'DC' cast on the face of the flywheel). Mark that fin with white or light yellow paint. Cylinder #1 is the closest one to the flywheel on the left side (viewing the flywheel). There is a small hole on the shroud at 23 degrees BTDC. Use a timing light and make sure the engine is running at least 2000 RPM; the fin you marked should be in line with the hole.
So I found and marked the x but where is this mythical hole you speak of? Possible to get a reference pic?
Thanks for the photos……this is an interesting machine for several reasons to me. First it is only the second M-600 that I've seen that does not have the corner braces (for attachments) yet it has a '68 manufacture date, while the other '68 M-600s I've got in my data base all have the braces. Secondly…it has the front hooks (for attachments), making this the first machine I've seen that has the front but not the rear capabilities. Sometime in '68 they switched the back support to a design that has a strap connecting the two uprights and stayed with that design until they stopped making the M-610 in 1982, yours does not have that feature. I know you've said before but where are you located? I've got all sorts of parts I could help you with. Also…….the timing mark……It depends on where the sheet metal came from. I've seen it a number of different ways…….sometimes the flywheel screen is bolted to the shroud and will have a notch in the screen frame, sometimes the flywheel screen is bolted to the flywheel itself and the timing mark will be a notch or as Mark mentioned, a hole in the shroud. Most of the time there will be two marks (one for VF4D and one for VH4D) and as you look at the flywheel they will be at roughly the 10:00 o'clock position.
Also…..I mix and match the sheet metal all the time……right now I have one machine that has no timing mark at all. I time it using the "by guess and by golly" method. Not good but it has run for many years that way.
So, I'm from the taunton Massachusetts area. And I found the two timing marks. They are small notches indented into the sheet metalI'll toss up some pics adyer .
Yep…..hard for me to help you that far away.
No worries. I've rebuilt cations truck and car motors. This little guy can't be to difficult. The only thing I have yet to figure out, maybe you can shed some light on it. The governor, is it supposed to be spring loaded one one direction or the other?
Also, any information you can send my way about this machine I would appreciate it. And what types of attachments the front hooks are for?
Here is a online V4HD service manual. It might be able to help you out and answer a few questions for you. Also, as a side note, you can trust 6bnorna, and Tazza, skidrow and a couple others. Those guys give accurate trustworthy info, I never mind being corrected by those guys. They are not key board know it all's and always help. Here is the web address for the manual, sorry I don't know how to make it a hyperlink so you most likely will need to copy and paste to get to it. http://www.wincogen.com/files/downloads/winco_engine_maintenance/wisc_vh4d_repair_manual.pdf
Forklift mast, backhoe, broom sweeper, snowblower, sickle mower……there were several other attachments but I'm not sure which used the hooks and which only the boom arms. There was a cotton bale clamp, post driver, tree digger and vacuum sweep that I believe used only the arms. Probably more.
I meant help with parts……..I don't have time to turn a wrench for someone else. Yes the governor has a spring……..careful that the VF4D and the VH4D have a different adjustment on them so your M-600 manual will not show the VH4D adjustment as it came original with the VF4D.
Oh, yeah. The only help I'll be needing is knowledge. I'm no stranger to fabrication and mechanic work. I may be an engineer but my second home is my garage haha
I'll have to pull the governor off tomorrow and see if the spring broke. The arm just kinda floats in the wind..
a few more photos to bring it up to date.
still haven't figure out what would cause the pitting on the head, any takers want to venture a guess? the piston surface is completely smooth.
only had to do little bit of carbon clean up.
timing marks? I filled in the notch with pen to see it better. there is one here, that lines up with the X at TDC and there is one at 12 o'clock as well
I read that it should be 23 degrees of timing at 2k rpm. but how does one time a motor when you only have 2 lines to work with?
