INSTALLED A MIRROR ON A LX665
MUDDY JORDAN
I bought a nice lx665 that runs great everthing worked fine, I asked my diesel mechanic to install a mirror next to the computer board overhead. No problem, he disconneced the board and blew it off, installed the mirrow after removing the plate, reinstalled everything, now I have a buzzer going off and the bucket will not function. The lights and display on the l.e.d. now do not function. Is there a way to reset the computer? Is the board that fragle? Is the only option to replace the board? How can I be sure it is just the board and not the computer? Muddy Jordan
I assume you checked all the connectors he removed?
Even check that when the connector was removed it didn't break off a terminal that may still be in the socket end of the connector.
Ir sounds like a safety interlock problem, the seat bar or seat switches were not fiddled with?
Can you back out any screws he use to install the mirror? Might be the tip of one shorting something out in there. if a installation causes a problem you just have to work backwards through it till you find out why. Before you remove the board though disconnect the battery so there is less chance of accidental contact.
