Thanks my problem is that the EIC do not turn on... And i put on service and the engine turn on and move back and foward, but in run nothing happen... That occur after i wash the equipmentThe fuse is in the engine compartment fuse box. Remove the cover and you should see 2 fuse blocks. The fuse is in the right fuse block and the second one from the bottom. It is a 5amp fuse.
Do the instrument panel lights come on when you sit in the seat? If so the fuse is good.
Will the engine start when you place the service/run switch in the service postion?
If you search through this forum there was a link to free electronic copy of the service manual here. Don't know if it is still usable though.Thanks my problem is that the EIC do not turn on... And i put on service and the engine turn on and move back and foward, but in run nothing happen... That occur after i wash the equipment
Here is the link again, it should continue to work. Manual is for the LS160 LS170 but is the same as the lx565If you search through this forum there was a link to free electronic copy of the service manual here. Don't know if it is still usable though.
Thanks for the link....anybody have idea why the ECI not power onHere is the link again, it should continue to work. Manual is for the LS160 LS170 but is the same as the lx565
http://www.mediafire.com/?ux89bq2u4u3ug
The manuals have pretty good wire trouble shooting, it should walk you though. There is some info on whick pins at the eic have power, if the power and ground is there then the eic died.Thanks for the link....anybody have idea why the ECI not power on
Thanks for the information to all. I am waiting for the EIC it is on electronic center to verify itThe manuals have pretty good wire trouble shooting, it should walk you though. There is some info on whick pins at the eic have power, if the power and ground is there then the eic died.
Hopefully you find a bad ground or power conection.
