S split Member Joined Aug 25, 2013 Messages 13 Aug 30, 2017 #2 Anyone know the process for testing the Hydraulic pump on a 319D or 323D? I suspect that the output is weak.
T Tazza Moderator Staff member Joined Dec 7, 2004 Messages 16,864 Aug 31, 2017 #3 You really need special gear to do it, really it should go to a hydraulic shop to test. You need to restrick the output and load it down to get up to the rated pressure then test the flow at said pressure to know if it is weak.
