Hyd Fluid Fill Port
Bljacque
I have a Case 1530 in which I would like to drain & replace the hyd fluid. I have located the vent cap on the left side of the uni-loader but have not been able to locate the actual fill port. There is a fill port toward the back which I initially thought was for the hyd fluid but when I took the cap off it smells like gas so I'm not sure. There is another fill spout on the right side of the uni-loader which I have been using as the gas fill port but not sure what the fill port on the left is. I did purchase a set of books for the uni-loader but none of them provide a description of where & how to replace the hyd fluid. I expect that they assume that this is covered in the operator's manual (which I do not have). If someone in the forum has knowledge to share on this issue it would be most welcome.
Here's a link for a service manual http://www.tractorpartsasap.com/Service_Manual_Case_Skid_Steers_1500_1526_1530_p/122578.htm On my 1840 its on the right hand side just inside the rear door big silver vented cap
Or you might be able to figure it out from this decent parts break down for 1530 on this link. http://www.messicks.com/CAS/67863.aspx
