Help with an Electrical Issue
skibum0607
A few days ago the backup camera I installed stopped working (connected using a fuse tap attached to the 15A Accessory Fuse). I also noticed the front and rear work lights and the wiper aren't working as well. I suspect either a ground or a relay problem, but I'm hoping someone here who is more electrically capable than me can point me in the right direction or give me some ideas to test it. Thanks in advance.
I forgot to mention that it's a NH L223 and everything else seems to be working fine. The machine starts up with no trouble and all the mechanical and hydraulic controls are functioning normally.
Never mind guys.... I found the problem. I swapped some of the relays around and found a bad one. Replaced it and now back in business.
Glad you got it fixed, i had issues with my S150 that managed to get wmoisture into the fuse box, it messed up 2 relays, swapping them around found the bad one.
