What is a good used skid steer model to buy for a short term project and then sell when done?
macallan
Hi I have a short to medium term project, maybe a year, and am thinking buying a nice skid steer that I can easily sell when I'm done with it for about the same as I paid for it. It won't see heavy or hard use.
No real price limit. I'm more looking for a sweet spot in the used market where there will be a steady pool of buyers.
The one thing I need is an aux flow rate of 17gpm min, more would be even better. An enclosed cab with AC would be good but not necessarily required.
Anyone have suggestions?
Thanks!
-MC
this is like asking what are the best number to pick to win the lottery
its impossible to suggest a used machine for you,
we have no clue what your needs are for it, , what size machine, , wheels, or tracks?
how new or old?
can you do repairs, and or fix things yourself? what is your skill set on doing repairs/
next is, there is No BEST model machine that last forever , is problem free and or holds its value better than other models!
wanting to buy something, use it for a yr and sell it for what you paid for it,??
is asking a lot!
as hours added to any machine lowers its value,, as does wear and tear!
using a machine adds wear to pin's bushings and buckets and hoses , tires, tracks,and so on!
its impossible to not have wear and tear if you use it
and even age alone lowers values!, as hoses dry out over time and can crack and need to be replaced and they are not cheap to replace, and many are time consuming to get off and re install, requiring skills to do so! plus older machines can be harder to find parts, as pending how old, many are no longer even made!
so, wear and tear and AGE can cost $$$ and lower values of things! just no way around it!
unless you happen to BUY a machine at less than its really worth and then your ahead of the game, but few folks sell things for less than they are worth!
what you BEST option might be, is to find the best condition used machine that fits your needs, that has local support(as in brand dealer near by)
and from there use with care, do PM's as needed and not abuse it, and when done, look up market value and try and get that for it!
if you do NOT know what to look for on used machines, I highly suggest taking someone with you that does when you go look at possible machines! it can save you a lot of $$ , as sadly many sellers today are scammers, and will not tell you the real history of a machine, or maybe even know it, and will want money over being honest!, its a sad world were in these days ,
buyer beware has never been higher risk!
Definitely a hard question to answer. I picked up a 1993 853 a couple years back with the intent of selling when I was done my projects. My budget was my restriction on purchase, hence the dated equipment, but given its straightforward mechanical/electrical set up (no Boss, or computer etc.), it's not as challenging to work on as I had originally thought. That said, I quickly realized it's far too useful to ever let go........:)
If you would get a Bobcat T740, use it for a year (~1000 hours) you could easily sell it for the same price you bought it.
These machines are strong and very popular because they don't have the DEF after Treatment System on but the same Engine/ Pumps setup as the T770, which has DEF System.
When I worked at the Bobcat Dealer, we could not keep a T740 on the yard. They arrived and were immediately gone.
These machine have all your requirements and you can even choose between Joystick and Manual Control.
The answers above pretty much cover it.
Without knowing what your projects entail, it's really difficult to make suggestions. You do mention a 17gpm requirement, so start at that point in the specs and look at those models that offer that or higher. Then it comes down to what's available and what is locally supported. Don't buy the only XXX loader out there if there isn't a dealer around for 150 miles just because it is cheap. Don't buy something needing work if you aren't mechanically handy. Also, make sure your loader works with the attachments at the local rental yards in case there is something special you need for a limited time.
And I totally agree with FJRDarksider... I was in your position when I started building my workshop over 25 years ago. I looked at renting a skidloader for a weekend here and there to do this or that task and started adding up the rental fees. Then I looked at what was available for sale and realized I could spend the rental money on actually buying a used machine and then sell it when I was done. Even if I didn't get the full purchase price out of it, I'd get more than if the money just went to the rental yard. Plus, I'd have it around for other tasks I likely wouldn't bother renting a machine for and could do things on my schedule instead of "saving up" tasks to do on the weekend I rented it. Not only is the skidloader still here, but I added a grapple bucket and forks to it and then a mini-excavator after a few years. ;)
Not going to get into specific specifications, only you can analyze which model would suit your needs.
That being said, CAT and Bobcat tend to hold their values better than most. Look around and see what local contractors are using, that will give you some indication of dealer support too.
Don't go too big or too small and you should hit the largest market when the time comes to sell.
