Help buying skid steer
agonz11
Sup guys my dad is looking for a skid steer. Mainly bobcat I guess? I know nothing about them and he doesn’t know much either. He will be mainly using it around our property to move dirt around and for his concrete business when he needs to do demolition so moving broken concrete, dirt and will be buying a concrete breaker to break the concrete. What are high hours for these machines? What’s the difference between s510 s770? Any other brands or models you guys recommend? Thanks.
first off welcome to the site
next, as for what is HIGH hours on a skid steer, I think when you get up past the 4000 hour mark, your in HIGH hours, IMO
but keep in mind, that hours alone do NOT tell the story on condition or possible failures, of a macine,
there is a lot more to consider,
HOW the machine was cared for or NOT cared for matters, same as how the machine was used, or abused
a bad owner, operator can ruin a machine in a short period of time, where as a well cared for machine can last a LOT longer than normal!
there are tons of web sites that show spec;'s on machine models, I'd suggest looking at one of them to compare the specs of the machines you listed, to find out differences,
as for other machines to consider,
look at them two machines your considering's spec's and match them up with other machines that have similar features, weight of machine, HP< FLow rates, break force, and so on!
I would personally think if your using a machine for breaking concrete up, you want a HIGHER HP and heavier machine, to take the abuse of doing that work!
I would also, be maybe considering a CTL (compact track loader), from my point of view , they seem to have more stability when loading slabs that extend past a bucket or with a grapple, and many can be had in heavier weights to again handle the abuse a breakers adds to things!
I ideally I think you would want an excavator for the breaker work, if your going to be doing a ton of concrete work, just seems a better tool for the job!
also, keep in mind having good dealer support is valuable, so try and stick to brands that have dealers near you!
as down time can be a costly things, off brands can me longer waiting time on parts, shipping and ordering online is great, but these days shipping can be a gamble and a lot of down time
so having a good dealer with a good parts supply on hand is worth a few extra bucks when buying a machine IMO
You can go over specs of current machines on Bobcat's website: https://www.bobcat.com/na/en/equipment/loaders
The simple answer is the higher number machine will have higher horsepower and rated operating capacity. Other differences may be radial lift path versus vertical lift path, high flow hydraulics for attachments, and other options.
For older models, they also have historical specs: https://www.bobcat.com/na/en/equipment/non-current-models
Ok thanks well we ended up buying a 2015 bobcat s510. Has like 1300 hours. Runs good seems fine to me. Plenty of power for doing things on our property. Just gotta buy a concrete breaker now.
