Well after disappointing compression readings on the wisconsin vh4d, I jumped in the truck and headed to the mid north to pic up a Hatz Z790 mil spec. Dimensionally, similiar with an identical shaft output. Currently I'm doing the swap on the 70's era OMC skid steer. With a built in alternator in the z790 allows me to pull the old alt out and use the place/pulley to power the hydro pump. Since i repaired everything else on the machine, particularly the variable drive, I basically chased the weakest link to the motor. My question is since the hydro pump was run off the dizzy originally, what is the suggestion for pulley size since it will now be powered by the jackshaft?
