grumbling fan
jessemead
i have a 97 763. when the skid sits and idles the fan makes an annoying grumbling noise. has anyone heard of this and how do you fix this problem
Probably your bearing is going bad in the fan gearbox. The seal under the fan often fails, and moisture eats the bearing. Sometimes the oil leaks out of the fan gearbox and it runs dry. Take the belt off and rotate the pulley by hand. Any resistance or noise you should pull the fan gearbox out.
do i have to lift the cab to check this out?
