Steelart99
- Joined
- Apr 27, 2016
- Messages
- 10
I have an old Eric 4850 (same as Ford CL40) skid steer that has been re-powered with a Nissan B310 engine. It is definitely a 'hobby' machine with numerous little issues. I finally got the engine running (albeit roughly) and can drive it around. Lift and tilt work, but with some oil leakage in the valve assembly. Here is my current issue: When I drive the bucket lift on this, there is a stuttering in the movement. My guess is that one of the lift cylinders is not working or is dragging somehow. Is there a way to figure that out? In a parallel system, how do you tell if one cylinder is getting pressure? Might there be another problem that would cause this symptom? Since is does lift, I would assume that the lift valve is getting oil out to the lift cylinders. I have a little bit of hydraulics background, but not enough to be able to narrow down my issue here. Any help would be appreciated.
