DIY cab enclosure
uffda
I have 743 and would like to get it enclosed. I thought I would use lexan over plexiglass, would this be a good choice.
on my 1845c, I used lexan. Welded up a front door with a U channel and slide a piece of lexan in.
Then bolted 2 more peices directly to the ROPS on the side.
Worked great for many years and kept it toasty in the cab while plowing.
What did you do for a heater? Did you make your own and where did you install , not much room.
1845c has plenty of space on the rear deck above the engine.
I ran a coolant heater mounted up there with lines down to the engine.
Only downside was the heat didn't get down by my feet.
