2015 s650 no cab heat
Jakepabst88
My Bobcat has no heat in the cab this year. Both lines to the heater core are hot and I've replaced the heater valve. Stumped.
if both hoses are hot ,I would think that the coolant is circulating and if that is the case the only thing can think of is that the fan is not running to move the heat into the cab. A friend of mine had to replace the fan motor speed switch that was all burned up on his s185 ,maybe that is your issue too.
my 590 lost heat, turned out the resistor was bad, funny thing I replaced it with a new one, kept blowing the fuse, on inspection the wires on the plug were different to the original so went to dealer looked thro his stock they were all wired wrong, they pulled the wires from the plug end and changed them to the original problem solved.
Funny the resistor pack was assembled in Mexico, wonder how Bobcat resolved than one
